Miscellaneous suggestions
Lady-Natalya
Re: Miscellaneous suggestions
Super lag problem makes game basically unplayable. Not sure what causes it, but it happens even when you do it with like only 2 people.
In the future, post a new thread in the bug forum. Don't just reply to a random thread in the wrong forum. Keeping things organized(especially with the bugs) makes it much easier for me to keep track of it.
I need as much information about the lag as you can tell me. Does it happen EVERY game? Is the lag the same throughout the game or does it get worse as the game goes on? What's your fps when you're lagging?(ctrl+alt+f to check) Did it happen last patch as well or did it start happening recently?
EDIT: This is not my fault. All custom games on battle.net seem to have the same issue. Check out the comments in this thread: http://us.battle.net/sc2/en/blog/6830760/Patch_152_Now_Live-8_21_2012
This means that there's nothing I can do right now. I'm sorry.
Lobster
Size about ships and cruisers
I just want to talk about the size of the units in this game, I found out it is weird because the cruiser is pretty small but it can contain such a huge amount of things.
So, I wish you to increase the scale of the cruiser to make it looks bigger and also you can make the normal ships smaller, I wonder how to destroyer dock when it is almost
as big as cruiser
as big as cruiser
I agree, but making stuff super realistic wont be good. I think the BC would be a LOT larger than the miner in real life for example. Normal SC2 has the same problem and just scales the units to a decent size.
I might make the BC's slightly larger, but I wont change the size a lot.
Save the music settings in the bank. I personally like the music, but I think a lot of people would appreciate not having to type -music every game.
I totally agree. I'm personally getting tired of it as well. I will implement this soon.
Lady-Natalya
While you're working on that, maybe enable default SC2 music if you turned the CC music off?
Reduce/remove the cooldown on the power buttons. You can set the reactor from 0 to 200% pretty fast, but setting engines from 0 to 200 takes like a minute and it takes much longer if you need to mess with other power settings at the same time. If the delay is in the game for balance reasons, something needs to at least be done to make it easier UI-wise. I've had newbies on power get frustrated, and I don't blame them.
I reduced the cooldown of all the abilities and it made stuff a lot better in my opinion. It'll be in the next patch.
Jannik2099
Better Missile Control
I want to make launching missiles easier
The weapons-console should have the following buttons:
Fire all missiles
Fire all Piranha Light missiles
Fire all ... missiles
Fire all missiles
float like a butterfly, sting like a bee - Muhammad Ali
