New idea? ;)
Posted: Fri Feb 15, 2013 1:24 pm
by Navyseals
-i think a cool addition would be a Boarding Vessel. something that would cost a fair amount to buy. with maybe low shields and weak armor. but very fast, or vise versa. it would also cost to unlock it in the upgrades panel. so some new guy on the team wouldn't just buy one by mistake and go die. This would also make use more for the weapons on the units.
-possibly also Zerg and prottoss Fleet ship? such as a levi or a carrier. i know this would take A LOT of work but its just and idea
just a few ideas to spice it up ;D leave your suggestion bellow or rant on my topic :)
Re: New idea? ;)
Posted: Fri Feb 15, 2013 7:41 pm
Not really new ideas, but good ideas indeed. Boarding is coming, but it's a lot of work and I am prioritizing a lot of other things. That's why I implemented the weapons.
As for zerg and protoss ships, it's not really possible right now. The problem is that there's no space to put the interior. The map is filled with nowhere left to put stuff and it's already at the maximum map size. If the maximum map size is increased in the future, it might be worth considering, but until then it's not really possible :(
Re: New idea? ;)
Posted: Sat Feb 16, 2013 3:13 pm
by Karl913
Maybe, maybe not.. This is an idea that l've had in my head a long time, and many maps do it.
You could, rather than increasing the map size, decrease the size of everything else. Interiors are fine, but maybe you could make the space map 20x more zoomed in/ships 20x smaller. Then you'd limit the view of players on the minimap, and make the actual space part of the map.. Well, you could make it 5x bigger, according to us, and it'd still be smaller. Then you'd have a -lot- more room for anything else you want. This would only work on the space part because of the no-cliffs and everything would look the same, while interiors would be much more... Pixely and walls would be very high. Still, with this, you could get a lot more room for things.
Re: New idea? ;)
Posted: Sun Feb 17, 2013 8:17 am
It's a good idea, however it's not viable. There are several things that cant really be scaled down properly and there are other problems as well. Basically, it will become very inaccurate if I make the space more zoomed in, which means the ships will stutter forward and everything will look very bad.
Re: New idea? ;)
Posted: Sun Feb 17, 2013 12:08 pm
by Karl913
Alright.. Well, how much room would there be for protoss?
Had an idea for zerg, them building out rather than in. Kinda awkward being in a leviathan, don't you think?
Maybe all the players start as overlords outside the leviathan, and the overlords have different 'abilities' or menus instead of the usual consoles? l don't think consoles belong in a leviathan either. :P So, they could do everything from outside.
Not much else for me to say, haven't thought about it to much. Just an idea. :)
