Patch 1.5 published
Posted: Thu Feb 28, 2013 7:24 am
The new Cruiser Command patch 1.5 is now published(or it will be within 10 minutes of this post). Here are the patch notes:
v1.5 (28/2 - 2013):
- Reinforced hull upgrade now increases Chomper hull by 100 instead of 50.
- Magnetic pull energy cost decreased from 150 to 100.
- Added two chomper upgrades. Gravitic pulse and Core overdrive.
- The chomp cooldown no longer triggers when you target an asteroid out of range.
- Increased chomper speed by 20%.
- Ships no longer collide with other ships 4 seconds after launching.
- Kermiculite cost of mass replicator increased from 30 to 60.
- Added a directions dialog.
- Improved the in-game tutorial for beginners.
- Fixed the upgrade glitch for real (I promise)
I still haven't been able to fix the kermiculite issue, I'd appreciate replays with that happening. Does it happen every game?
Edit: I might've fixed the kermiculite issue. Tell me if it still happens in the new patch.
