Engine Boost
Posted: Thu Apr 04, 2013 4:10 pm
After playing a bunch of maps, I've come to understand just how powerful Engine Boosts are. They're a make or break of combat that feels so essential that it basically allows you to leap across the map at the small expense of a little power. So, for those unfamiliar let me just list a few things...
Instead of making it cost BC Energy to do a boost, make it cost some resources, I.E. 10y 15r. "Burn resources" for that extra jump. That's the sort of cost people will cringe at in the beginning, making them think twice about utilizing it immediately as a better method of movement. It also forces people to stockpile a bit further if they believe it's going to be a prolonged battle, and also puts a situation where people may think to use normal Engine Power instead of the Boost in order to conserve resources early on. (Though I think in the case of a rush, most people would still boost one for one if both had. However, if only the escapee has it, it puts a small hamper on resources that he wouldn't have had to deal with originally.)
Any thoughts on this?
- The current cost of Engine Boost is 200y 50b 200r. I find this to be a good price considering the potency of the actual engine, but it's still very manageable.
- (IMO) Those with Engine Boost are able to easily control the flow of combat if the opposing team lacks it. It is extremely simple to 'escape without issue' using one swift engine boost, giving ample time to either make preparations for combat or simply wait for the next boost. Most players will not be able to close the distance in time. On the other hand, it's nearly impossible to escape from someone who has an Engine Boost due to the distance covered.
- Engine Boost is something operable on navigation. One of the most painful parts about moving a BC alone is that you have to go back and forth between the Energy Console and the Navigation Console. But with Engine Boost, you can simply operate it all from navigation without any sort of macro difficulties.
- Many consider Engine Boost to be absolutely 'core' for the game. It's something that cannot be done without. Isn't this already an implication that this ability is a bit overdone, if it literally makes or breaks a BC?
