Disconnecting players from consoles, console unusable
Posted: Tue Apr 23, 2013 7:36 pm
by zakhennahr
After disconnecting an AFKer from the weapons console it was no longer usable. Two of us selected 'disconnect' then clicked on the console then it was no longer usable.
Re: Disconnecting players from consoles, console unusable
Posted: Tue Apr 23, 2013 9:01 pm
replay buddy or he cant fix it, he has to see the issue to understand the coding error which caused it. This is an issue hes addressed in the past so if you can provide the replay. Speedyshare.com is where you'll want to go to get it done fast, just save the replay in game and you'll find it in your private starcraft 2 my documents replay file.
Posted: Tue Apr 23, 2013 9:16 pm
by zakhennahr
My bad. Didn't see that in the 'how to post a bug report'.
Code: Select all
http://speedy.sh/yBnH5/Cruiser-Command-Disc-Bug.SC2Replay
Happens anywhere near the end on my team.
Posted: Sun Apr 28, 2013 6:08 pm
It's hard for me to test this in single player, but I've looked through the code and found an error which I've corrected. I'm not sure if it'll correct the problem but it seems likely.
