Redirect power
Posted: Fri Nov 02, 2012 2:29 pm
Examples: You can put let's say 200 GW to engines... and if you cut engines then that 200gw is wasted... it would be cool if you shut down the engines ... all the power that should have gone to the engines would go back to the main capacitor ( that's what would happen in reality right? ) and when you power on the engines ( maybe add a 2-5 second casting time ) use power relative to the max speed... so you max the engines... you use 100% of what energy you put in them... if you slow down (s) to half of the max speed ... you only use half of the energy put into shields.
This would make the bc much more maneuverable especially in early and mid game ( the bc is basically just a sitting rock that has lasers in the early part of 90% of games ) and also would make the energy guy not spam the power console to cut power to the engines
Another interesting ideea but one that needs to be thought out properly is redirecting power from one part of the ship to another... right now you just power up what ever you need and power down what you don't ( and it takes a while )...
Example usage:
Let's say you're in a battle and you think you don't have a chance of winning and would like to run and regroup... right now the only way to do is ... is boost and hope you can juice up the engines fast enough. But if you could instantly redirect all power from weapons or shields ( or both ) to the engines and then boost... you would be a sitting duck... but a very very fast sitting duck
Same goes for shields and weapons, example: you have 100GW in shields , 100GW in weapons , 100GW in engines... if you stop ( and taking into account my first suggestion ) the 100GW from the engines would be redirected back to the capacitor because it's not in use but if you could instantly redirect power from the engines to the shields that means you could switch 100GW from engines to shields just like that... and that could be a life saver
( think lots of missiles )
And weapons: you're out of power in the weapons capacitor... the enemy also... what can you do? redirect all power from engines and shields to weapons and blast them to hell
( or keep shields on if that's what you want )...
Together theese 2 features could make a far more interesting game... both in early and in late game.
Let's say you put 500GW of energy in the engines from the start but keep them off
when the kerm comes up you can get there in no time
( so could the enemy )... and the fighting begins.
Example usage:
