core glitch
core glitch
after the resent update (0.999g) the core goes down from 100% to 2% from just one sabertooth missile then with the ones after it went down less with one salvo core dropped to 0% but bc did not blow up untill i used the shield thing that does core damage every second that it's on.
Re: core glitch
You're on NA, right? People on EU complained about this as well so I found the issue and fixed it. However I was so tired yesterday so I went to sleep without publishing it to NA. It is now publishing as I write this.
