mb he already has a smart program that reads forums and gathers knowledge to auto heavy code itself, and each reply you post is being run through by that program as well. One day we'll have an AI that you can set up from lobby, with different skill levels... top skill will know where all the minerals are and see all the map at start, getting data on your every move, reading your energy, shields, power, ups, EVERYTHING! It will foresee and counter your every moveTempest wrote:he does, worst yet Insomni has access to everybodies private forums, Reading, Countering and eventually defeating any strategy we think up through heavy code!!! We are doomed.
power management ai
Re: power management ai
we should just start posting absurd methods such as "at start set core to 200%" then we can beat these machines.
I'm sure they also foresee the results and remove such... the only way of winning now is to start construction of a teleportation device, to send someone back to 2010 to prevent all this. Our present is doomed in our future, but there is still hope for parallel universeTempest wrote:we should just start posting absurd methods such as "at start set core to 200%" then we can beat these machines.
Who is going back... Lets send dumbmarines hes combat trained.
Nooo, why killing Siretu? i still want to play cruiser command :S we just must mislead him, so that he never makes his AI do anything else then simple refining, that way we will be safe, for now...Tempest wrote:Who is going back... Lets send dumbmarines hes combat trained.
The problem is, he's a bit dumb (No offense, DumbMarine)
You calling the terminator smart?
http://www.youtube.com/watch?v=VZqfUzax3kE
he went back in time to kill people and did a pretty good job for the most part! just killed the wrong people.
i think dumb marine will be fine compared to THAT
Jannik2099
if we go back in time and stop the coding of advanced ai, we wont think of an ai now then we wouldnt have a reason to send somebody back in time and so it wont happen... to say it short: we are doomed
float like a butterfly, sting like a bee - Muhammad Ali
damn it hes right.
