Patch 2.1 published
Patch 2.1 published
v2.1(29/4 - 2013):
- Fixed a boarding bug that would occur if you die on the enemy BC.
- Fixed a boarding bug that would occur if you die while on your way back from the enemy BC.
- Fixed some boarding item tooltips.
- Added a new ability to the Infiltrator: Phase shift. It’ll make the infiltrator pass through anything for four seconds.
- The directions button and the switch view will now be hidden while in space.
- Nanite transfer now heals 3% / second instead of 20 / second.
- You can now board while being recently launched.
- Might’ve fixed an issue with using the Disconnect console ability.
- Fixed a Scorpion Light Missile bug.
- The Destroyer’s Quantum Leech now scales with the destroyer damage upgrade.
Use this thread to discuss the latest patch.
Capricis
Re: Patch 2.1 published
Post by Capricis »
COOL PATCH
Also your loading screen still says the forum is sc2cc.forumotion.com.
when can we start adding upgrades to missiles? (i also feel heavy missiles tier should be unlocked)
such as scorpion missile, allows little projectiles to home in making them more effective at hitting multiple ships
WildFire
Neph
Post by WildFire »
small ship killer missiles!
Leader of Nephilim
What is the exact formula for quantum leech energy damage now?
3000 + 500*quantum bombardment level?
200 + 150*level
I see.
Your numbers are per projectile, I guess?
1000 energy per salvo if not upgraded,
4000 energy per salvo if fully upgraded.
Sounds good.
Jannik2099
Post by Jannik2099 »
sounds fucking much. its upgraded to 400%, while the dmg upgrade does 100 or 125%
float like a butterfly, sting like a bee - Muhammad Ali
Jannik2099 wrote:sounds fucking much. its upgraded to 400%, while the dmg upgrade does 100 or 125%
What are you talking about? It's nerfed. It used to be 5000 per salvo all the time.
IvanX
Post by IvanX »
Well, the only problem with Starting at 1000 that i see is that you get +75% at lvl 1, making lvl 1 upgrade a must have,
while if you started at 2k (it'd be just either 25% per upgrade if u wanted to cap on 4k)
(or 37.5% per upgrade if u wanted to cap at 5k)
As from what i think 40% per upgrade for dessie is perfect, thus
base should be 1600 and 600 per level, then at lvl 4 it'd do 1600+4*600 = 4000, while compared to base damage each upgrade would be 37,5%
