Patch 2.5 published
Patch 2.5 published
v2.5(24/5 - 2013):
- Fixed a bug which could happen if you used launch infiltrator several times in a short period of time.
- When switching to a drone, the order dropdown will also switch to its current order.
- Changed the Repair Bot death sound to Mule death.
- Updated the tooltip of Nanite Transfer to correctly show the new percentage-based heal.
- Updated the fusion core upgrade tooltip since it isn’t actually supposed to impact core recovery.
- Changed cost of mass replicator from 120/120/120/60 to 100/100/100/30.
- Fixed a resource refund glitch.
- Added a new AI role: Science console. The AI will automatically power transfer nearby friendly ships, purge core when necessary and use iron curtain when useful. It will also load the yamato if you set that option in the drone console.
- Fixed an issue that could happen if you launched too many ships at once.
- Fixed an issue where killing drone miners would cause an internal navigation slot to become unusable forever(related to bug fix above).
Re: Patch 2.5 published
Shiny.
Hopeinmo
ZergCC
Wiki edits: 6
Post by Hopeinmo »
Ooo, 1 step closer to AI dominance XD
IvanX
Post by IvanX »
Doh, now buying a science drone is a must >.>
What about the resources bug? haven't found what's causing it yet?
Siretu wrote:v2.5(24/5 - 2013):
I did find the problem, and it should be fixed now :)
