Sensor Types (Pings)
- Corinthian
Before I place this in Suggestions, I want to know what others thiink.
Each small ship could have it own Sensor type, each available for upgrade, each color coded.
Currently:
BC = All ship Ping (Enemy Red, Ally Green)
Miner = Scanner Sweep (Asteroid Color)
Wraith = Miner Ping (Yellow)
Proposed:
Corvette = Wraith Ping (Orange)
Destroyer = BC Ping (Purple)
Chomper = Asteroid Ping (White)
Minelayer = 2x sight radius for 1 second.
Currently:
Proposed:
Re: Sensor Types (Pings)
i like the fact that your not sure what combat ships are what, which is why i proposed a scout small ship designed to bring clarity to the confusion. but the pings would shut down so much potential for radar strategy, and chompers shouldn't have the asteroid ping but rather the 2x sight radius, an asteroid ping would just be a little too awesome for the other miners in the game. if it did have an asteroid ping it would need to be within a small range not the whole map. corvette can have the wraith ping but that ship already has a large demand of energy consumption and personally as a wraith fighter i like being able to strike outside of range and get the jump in combat on such a close range dependent ship but i suppose it would be fair seeing as i cant die to an equally upgraded corvette
the destroyer ping is what bugs me most, you cant cloak a bc, but you can maneuver it and its small ships to create radar confusion which i believe is sooo awesome, so deep and can be so strategic. id hate to have an enemy that can bring clarity to all that confusion that easily. its tough for me to say but i think im against all the propositions other than the chomper close range asteroid ping, or 2x sight radius for a second for the chomper as well.
- Corinthian
You are right, the Destroyer Ping is a terrible idea, and an asteroid ping would have to be close range.
These are some good ideas, but there is another mechanic i would love to see included with pings. When a ship pings, it should also ping its location to the enemy.
This would add some great realism to the game. Pinging is using active sensors, and in today's wet navy active sensors light up your position to any ship with even rudimentary sensors.
More important though, this would add a whole new layer of strategy to the game. Players would have to make a tough choice while going in on the attack (in either a wraith or BC) and would have to either chose to attack on old intel and hope the enemy stays relatively static, or keep active pings but lose the element of surprise.
GoldenBoy wrote:These are some good ideas, but there is another mechanic i would love to see included with pings. When a ship pings, it should also ping its location to the enemy.
I agree on this. entirely
The Destroyer being quite a large ship, I dont understand why they would build it without a radar(and it has that big radar thing on top...). it should have a ping similar to the battlecruiser but with a twist : it should detect any ship in a medium range. (maybe about laser range?) only pings in that range would be detected.
it would allow the destroyer to track targets, without overpowering him because if he gets information, it means he is also close to the enemy and pings himself to them.
wow guys great ideas, both of you. i agree on both and dont see an issue either way. we should get a lower powered radar on the destroyer o.o. a navigation ping should announce your location to the enemy bc logically, it would however neutralize illusive radar mini map strategy whenever you ping to see your enemies location giving away yours.. another thing i was thinking about was those cool looking nebulas, i think you should have interference with radar when inside them which would add a clever twist to ambushes. Not saying to make the ping not occur, but maybe have it give an unclear exact location somehow? This would also encourage the creation of a ship designed to scout.
for the nebula thing, the only possibility I see would be to make 4 random yellow ping in a close area... yellow to show its a ping with noise from a nebula, 4 to make the exact position harder to guess
it would be awesome because you could hide a wraith, corvette, or whatever else in the nebula and when something comes close to explore you mess them all up.
- Corinthian
An upgrade, for a Destroyer 'active ping,' which shows the enemy BC up to laser distance away, could work.
I think making the BC ping active would cause problems. Though, we know nothing yet about the Sensor Console. If the Sensor console could take over the role of passive sensors, then I would be for the greater realism.
I like the idea of Nebulae providing detriments and benefits, but I suspect many players use Low graphic settings to insure there is no lag. At low settings only starless areas are seen.
Thats their problem :p
