1. If you place c-4 at the location that you leave the enemy bc, the c-4 will kill you once it explodes, even if you're out in space. At least I think this is what happens. I have 2 replays of this event. Note that in both of them the camera goes wack at about the time the c-4 explodes, and that the infiltrator was being repaired in the hangar even though I safely docked it. Also note: At about the same time it said something like "transferring your mind to a new body soon" in the subtitle area. Lastly, on the replay titled "Cruiser Command InfiltratorBug", I went back into the enemy bc later and noticed my pilot items sitting where I had departed from the enemy bc on the first infiltration. Thus I think it killed me.
2. If you press "g" when in an enemy bc to launch your infiltrator while NOT in the hangar, it doesn't launch, just as it says it wont. However, it DOES wait for the timer for launching and it DOES start the cooldown anyway. The worst part is it does not display the message that you can only use it in the hangar until after the timer finishes. If you can't fix the timer/cooldown issue, at least have it display message right after attempting to launch so there is time for the noob to react.
Replays:
"Cruiser Command CameraBug" - I realize this was a poor match, as there was a noob host who thought he could beat 4 of us by himself lol. But this does not affect the bug. Go to 16:30 to see the infiltration.
"Cruiser Command InfiltratorBug" - This was on debug settings. Go to about 7:00 to see the first infiltration and 9:00 for the second. Note the items left behind when the bottommost c-4 explodes. I had trouble moving the field of view in the replay, so if you do too try this: Watch "[PMGx]Puppetbones (4)" with player camera on. Then right before I leave the bc, switch to "Everyone (E)" and that will keep the field of view at the scene of the bug (lol that sounded weird).
Infiltrator Bugs
- Puppetbones
Infiltrator Bugs
Cruiser Command - InfiltratorBug.SC2Replay- (165 KiB) Downloaded 24 times
Cruiser Command - CameraBug.SC2Replay- (182.72 KiB) Downloaded 33 times
Re: Infiltrator Bugs
Thanks for the replays! In this case I'm very sure on how to fix both issues, so I don't think I'll need the replays, but it's awesome when people attach replays so I don't have to ask for it.
I'll fix them for the next version.
- Puppetbones
O.o....It's also awesome when the dev replies only THIRTEEN minutes later lol. I bow down to you for your devotion.
Never attribute to devotion that which is adequately explained by boredom.
- Puppetbones
