You can just have 1 ability, it will fire the missile then go down the list of missiles to the next one, which you press to fire, it might not be as precise as you might want to fire a predator missile, or sabers before hellfire missiles...but it allows you to *unload* quickly for players like me who have trouble firing missiles within 2 seconds (slapshot shamed me when he fired all 6 of his in under 0.5 seconds)
Also to small ships, it easily allows you to put in a cooldown as well, (as spamming missiles that insta kill might be OP)
4.12 published (beta) (You're welcome Dreadnought)
- Dreadnought
- Wiki edits: 22
Re: 4.12 published (beta) (You're welcome Dreadnought)
Beta updated with the following changes:
- Repair bots are now invulnerable
- Added Plasma automaton tooltip.
- Using repair stations while boarding no longer heals your battlecruiser.
- Increased hellfire fire amount from 3 to 10.
- Increased predator range by 20%.
- Spaced out marine spawn to avoid risk of getting stuck at start.
- Equipping adaptive photo disguise will now show you a message who you disguised as.
- Increased C-4 debris spread.
- Model and background choices are now saved in your bank.
Siretu wrote:Beta updated with the following changes:
What is that exactly???
For Gondor!!!
Subjugator's plasma automaton button was copied from the Point defense drone ability in SC2. The tooltip was never modified until now.
- DinoChicken
Many of these changes are excellent, keep up the good work!
I am guessing that you are saving patch 5.0 for a subjugator and destroyer revamp?
I'm saving 5.0 for something. I'm not sure what yet.
