Don't want this to turn into melee basing or something, but l'd like to see different stations that you can build/use and if it's the other teams, capture. Most would work together in different ways. A few examples:
Kermiculite Cage. This might even replace kermiculite fields in a way. What it would do is be a fairly large ring that asteroids can enter but not exit. This would be something you can come back to as a miner and mine all the asteroids.
Another thing would be an asteroid cannon, which would propel asteroids at high speeds and do large damage.
This could work well with the Kermiculite Cage to capture Kermiculite Asteroids, the most effective, and then load them.
Or, another station that you could place at different areas of the map to reveal a large area, and would be cloaked and very hard to see, and the best way to see one would be to run into it. With the current missiles, it would be easy to hit if you see it. Last thing: The Constructor could be used to pilot the asteroid cannon/other things and the asteroid cannon/other things would only work if being piloted. All these suggestions are unfinished and could -definately- use some balancing and discussion, if they are implemented at all. Absolutely nothing here is final.
New Ship: Constructor
Jannik2099
Re: New Ship: Constructor
please read other topics first: asteroid cannon, my idea station already have an own post
float like a butterfly, sting like a bee - Muhammad Ali
Actually, l do read other posts, but ask anyone and not many will read posts at the bottom of the page. Sorry for not noticing it. If you wish to hate, then please do it elsewhere. Also, after seeing your post on it the two are not the same idea. The asteroid cannon l have listed was my idea and was used as an example. l came up with it from another game l've played called AI:War. If you could ignore the similarities, l would be happy for suggestions.
