Bug report
Hazard
Bug report
Post by Hazard »
So i've been playing for awhile and these are the bugs that I notice the most
Email: Autin.igor@gmail.com
Ingame: Hazard
Character code: 772
Bug1: The wraith's R (Miner ping) doesn't work. Ever. Fix it :[ haha
Bug2: You can't take items down elevators. IF you have an inecapitated teammate on the bottom floor he's down for the ENTIRE game because when you walk onto the elevator pad with an item such as a repair kit/ Medkit it falls out of your inventory and lands by the pad. Meanwhile you go downstairs :[ Very annoying. Fix it :[
Bug 3: Much harder to reproduce and I'll try to get some replays but I've observed in the NAV console and Gunnery Console that sometimes when someone is lagging you and the Lagging box pops up when it goes down you can't get out of your console you just turn into a drone. You are not longer registered as using the console so others CAN use it but you're stuck in drone mode. Needs more research.
DestinyAtlantis
Re: Bug report
Post by DestinyAtlantis »
For bug 3, if there is no -unstuck/-stuck command(i am not sure how it's called) already, they should put one in(WC3 has one).
Warsign
Re: Bug report
Post by Warsign »
Miner ping stopped working after the inclusion of the stealth equipment patch. It could have something to do with that. As a little more help in tracking down the problem, miners controlled by drones show up perfectly fine using the wraith's miner ping (and the BC ping)
Re: Bug report
The ping should be fixed and in the new patch coming soon™(hopefully today)
I will investigate the item/elevator bug. I might do an emergency patch first to fix the big issues(mining stacking for example) and then an additional patch today or tomorrow.
I would rather fix the underlying issue, but in a map such as Cruiser Command, it is bound to happen from time to time so I'll add an unstuck command in a later patch(maybe today/tomorrow)
ConfuseRay
Re: Bug report
Post by ConfuseRay »
as of right now, (1.6), the wraith's miner ping still does not function. it pings friendly miners but not enemy ones.
Re: Bug report
It is fixed in the dev version which will be published in an hour or so.
MOJOJONO
No Emergency Miner
Post by MOJOJONO »
Just ran into this - I was exiting ship while under attack by enemy. I was destroyed and the message was : "Hostile Miner destroyed ...."
After that, we weren't getting any more emergency miners.
MOJO
Re: Bug report
It would be awesome if I could see a replay of that. Upload it on some file sharing site and link it here.
MOJOJONO
Nav locked out - managed to disconnect, but still I can't move
Post by MOJOJONO »
Here's one just happened.
Do not recall situation, but I was on NAV and all of a sudden I lost all controls. I could still see space and switch views.
Managed to get people to disconnect me, but my dude couldn't move away and do stuff. Fortunately, somebody else was able to take over NAV.
errr no replays.
Re: Bug report
I know of the bug and it's severe and game breaking. I'm trying to track down the cause, but I can't without your help. I need replays people.
Turn on automatic replays or save it manually(your last 20 are saved automatically).
Do you remember more exactly when it was played? I posted a new patch with things that might've solved the issue. I published the patch like 30 minutes before your post here on the forums. It would be nice to know if you played version 0.99 or 0.991
