Bug: Console disappearing
xscifix
New member
Post by xscifix »
I registered just to post this because I tried to play twice (and I loved the original for WC3 so I was excited to find this map) and it happened both times:
Just playing as normal, the first time I was on the power management console and the second I was managing the drones because a few people left, both times after I switched views a couple times the console was unselectable, and if I click on 'Select Console' nothing happens. I can't disconnect from the console because I don't have access to the commands. Other people can, at this point, run up to the console and take control of it and manage it normally, pushing my unit off the beacon.
I either have to leave or just stay and do nothing after this happens.
DestinyAtlantis
Re: Bug: Console disappearing
Post by DestinyAtlantis »
This is a known bug, and i think it is being fixed/already fixed, just not published/will be published with more bug fixes.
I didn't know of this bug, or maybe I'm misunderstanding it.
So to recap:
You enter a console(you can control the console).
You use switch view a couple of times
You deselect the console by selecting something else.
Now you cant even select the console? Are you sure about this part? Maybe you can select it but it's not owned by you anymore?
The Beacon goes blue(this is a guess, if it was still green, tell me)
Did you die when this happened? If you die by fire or something, it would kick you off incorrectly(Fixed in dev version, coming soon) which would lead to something like what you explained(people can take the console, you lose control of everything, select console doesn't select anything).
I might need a replay if you're sure you didn't die while using the console.
WildCat
console glich
Post by WildCat »
i had the same issue; here is the replay of it: http://www.mediafire.com/?u76wba2nbc9aaep
