Somehow the wraith emp has a few bugs going on
1. firing your emp can reset YOUR acceleration
2. Firing emp on another wraith has NO effect on boosting
Wraith EMP
Wraith EMP
Re: Wraith EMP
1. it resets your 2 bars completely. better spam W and it makes EMP all the more fun!
2. side boosting? ya i noticed you could still use it after being EMPd
Re: Wraith EMP
needs to be fixed, although i am enjoying this emp free combat between wraiths.
Re: Wraith EMP
using my emp also kills my OWN boosting ability. even when engines are not effected.
Re: Wraith EMP
This is very weird. Can someone attach a replay for me to watch? I found a bug with the EMP but it should have a different effect than what you guys are describing. I am publishing a fix for it to see if it helps.
Re: Wraith EMP
at 15 minutes, 18 minutes, and 22ish minutes you can see my boosts disabling as i use the emp on other ships.
Every combat situation on either wraith will show their boosts disabling whenever an emp is fired.
upon further review of the emp an enemy did fire an emp that i didnt see it was blocked by a corvette shot, but sky and redrocket have both claimed that it can happen, i just thought it did because they mentioned it after i had suspicion of it, i will study it further.
Code: Select all
http://speedy.sh/SShDg/Cruiser-Command-17.SC2ReplayCode: Select all
http://speedy.sh/CCWvj/Cruiser-Command-19.SC2ReplayEvery combat situation on either wraith will show their boosts disabling whenever an emp is fired.
