BC Explosion? Due to what? Huh O.o
Please explain me the BC explosion at the end of the game.
Weird BC Explosion.SC2Replay- (391.58 KiB) Downloaded 77 times
Re: BC Explosion? Due to what? Huh O.o
(i had a game where bcblew up, no power problems, no shooting at it, hull fine, couldn't see anything to set it off after i checked replay, unfortunately i lost the replay awhile ago XD)
Exactly the same problem as it was here.
I watched the replay. Your core stability was critical and low for a while. Even though stability was on the rise, my guess is that the way the game is programmed that this is why the BC exploded.
It's not, unfortunately. The ship explodes from core stability if the core stability reaches 0%.
It also exploded with the normal explosion model(there's a separate one if the BC explodes from core stability, it's a kind of blue ring)
