This may be just me, but I'm having a lot of issues actually equipping the Frequency Nullifier. Is anyone else incapable of putting it into the armor slot?
I'll attach a replay when I can of a game where it was impossible for me -- the issue has occurred several times, however.
Frequency Nullifier Issues?
Re: Frequency Nullifier Issues?
Right click null as if you put it onto the ground then just put it into armour slot with left, although it would be helpful to just have a right click and it automatically puts the item in the slot or out back into inventory (unless no space, ground). Its an old style, not alot of people are used to doing extra micromanaging
It will automatically put it in your normal inventory if you pick it up from the ground. If you have it in your inventory, you should be able to equip it normally by moving the item to the correct slot. If this did not work, it is indeed a bug.
I recently added some fixes to the equipping of the frequency nullifier. People requested that the frequency nullifier would not auto-equip when picked up from the ground, which would often cause you to faint because you didn't notice the life-drain until it was too late. If this is a bug, it was mostly introduced along with these changes.
Here is a quick testing I did of it. As you can see, it's impossible to equip the Frequency Nulllifer -- it gets pushed off instead to the second slot.
Nullifier Bug.SC2Replay- (28.61 KiB) Downloaded 58 times
I keep having issues with this as well, the solution seems to be to fill up your inventory such that the armor slot is the only one unoccupied, and then pick it up - otherwise it will end up in a regular slot and I am unable to move it to the armor slot
Hmm, I will take a look at it.
