missile launcher
DinoChicken
missile launcher
Post by DinoChicken »
the missile launcher on the far right, (the 6th one) does not show that a missile is loaded compared to all the other missile launchers
Re: missile launcher
yes I noticed this too. Neither does the far left one (at least on Battecruiser 2) Also, if you're on Battlecruiser 1 and go to the missile bay on the far right, you can see Battlecruiser 2's far left bay. Not sure if you can see the loaded missile or not, as I said it doesn't display it anwyway, but something for siretu to keep in mind.
Really? I missed this thread from before. That is really weird. Can you still fire it? Where does it not show up as loaded? In the BC status?
You can still fire it, and it shows on the bc status, and it shows up in the slots on the weapons console. It just doesn't produce the model on the actual bay itself when you load it.
Yes, please sign the change Dread's name petition.
Oh.
in battlecruiser 1 above the navigation console, you can see a little bit of the map, and occasionaly some asteroids and ships there, also the nebula spawn in the navigation, but i dont really want to get rid of that part, it looks cool, your stepping UP into the lofty helm in the clouds xD
Okay I think I found why this is happening: Last game I noticed the model of the missile is below the ground, like waaaay below the ground. So the height is the issue.
This is fixed in the dev version. Not sure about Battlecruiser 2, but it should also be fixed. If it doesn't work, please post here again.
