Patch 4.5 published
Patch 4.5 published
4.5:
- Added a hotkey for using flares on the corvette.
- Increased Corvette turning rate to 150.
- Increased Corvette speed from 0.7 to 0.8.
- Reduced to energy cost of Photon Barrage from 35 to 20.
- Fixed an issue with mine retargeting.
- Reduced Wraith damage upgrade from 20% per level to 10% per level.
- Offensive tier 1 now reduces corvette and wraith cost by 30% instead of wraith cost by 50%.
- Reduced Corvette reconstruction time from 360 to 260.
- When a player leaves, the ship is no longer destroyed. An AI takes control of it and flies it home.
- Economy tier 3 now reveals all the asteroids currently on the map.
- Fixed corvette attack energy cost issue.
- Switching between drones in the drone console now updates the order/status tooltip properly.
- You can now kick AIs off consoles by simply moving onto the beacon.
- Miners no longer feel safe close to the BC if there are enemies nearby.
- Photon rush upgrade modified from 90% cooldown reduction to 50% cooldown and 50% energy reduction.
- EMP with offensive tier 1 now only reduces engines by 70% instead of 100%.
- Offensive tier 3 now only reduces weapon costs by 20% instead of 30%.
- Economy tier 1 now increases mining speed by 20% instead of 15%.
- Econom tier 3 now increases chomper speed by 40% instead of 20%.
- Removed the spearhead engine from offensive tier 3.
- Economy tier 2 now also reduces Accelerate Mining Beam cooldown by 50%.
- Reduced wraith inventory slots from 6 to 3.
- Removed Reflective Shield’s energy cost but increased cooldown by 50%.
- Each level of improved hull now increases the cost by 5/5.
- Plasma Automaton energy cost reduced from 500 to 300.
- Horse prism drain reduced from 100 to 50.
- Drastically reduced all long upgrade times by 50-70%.
- Removed almost all scaling upgrade times.
- Teams now start with 3 wraiths.
Lots of changes. Go try them out!
(Currently publishing to EU, the patch is live on NA except for the last note which will be there soon)
Re: Patch 4.5 published
Give us spearhead boost
"Reduced wraith inventory slots from 6 to 3."
AWESOME
Lots of great changes here, thanks for keeping the game fresh!
AWESOME
Yeah I like the changes of this patch
Also your forgot to mention *CC now released on Korean servers.
That was a bit later.....Degra wrote: Also your forgot to mention *CC now released on Korean servers.
- DinoChicken
I like the drone changes, however i think that the missile drones are broken ever since the patch where you can place multiple missiles into one launcher bay.
they work.. somewhat, just not as efficiently as possibleDinoChicken wrote:I like the drone changes, however i think that the missile drones are broken ever since the patch where you can place multiple missiles into one launcher bay.
