Specs
Re: Specs
I'd assume specs would mean Specializations. I.E.:
Piloting Ace:
Ships controlled by this player move 10% faster.
Technician:
Ships controlled by this player gain an additional 1GW/s.
Guard:
This player has an additional inventory slot.
... etc.
Piloting Ace:
Technician:
Guard:
... etc.
Re: Specs
i also figured that was his suggestion, there is a topic up called Classes, and that seems to be a general thumbs up from everybody. Will take a while however.
Re: Specs
Specs = Spectator Spots. They have this ability in Star Battle. When creating a game you have the option to add up to four spectators. Spectators are able to see everything. In the game they can only communicate in the spectator chat. It's a great way for people to be able to watch matches and learn the game. It also gives the ability for a spectator to stream the match. In Star Battle tournaments some matches will have a spectator that streams the match with a small delay. This way people can see the match almost live.
Re: Specs
Ah, should've guessed that.
Basically, there are some issues. The best way would be to use the standard spectator/referee system, however there are issues(see http://www.sc2mapster.com/forums/develo ... -variants/). I checked out Star battle and somehow, it circumvented this bug. I have no idea how the creator did it. If you guys have any contact with him, link him the thread I linked and ask how he did it.
The second way to do it would be to have a specific slot for observers. The problem is that there's a limit of 16 players. 12 are used for players, 2 for the BC and one for neutral. Doing the math means there's one left(Hostile) which is a bit special and wouldn't work well as an observer spot, not to mention it would limit the amount of observers to one.
Re: Specs
I posted on the Star Battle forum and had a PM conversation with Zedu. He was very helpful and sent me screenshots of how his setup looks.
Unfortunately, I couldn't achieve the same result, even by mimicking his setup completely. I have no idea what the problem is.
I'll keep trying but I'm running out of ideas.
Re: Specs
That is unfortunate.
In the case you won't get it done, could you redo the 15th player slot into a spectator slot?
Someone capable of good livestreaming (good uploadspeed and 1920x1080 resolution monitor) could do it then (for example in the clan tournament).
